Any really bright (> 450 cd/㎡) strobed monitors?
In other words, an LCD that can match, or very nearly match, a quality CRT in terms of brightness, motion clarity, and input response? I tried a strobed display once but returned it because it was just too dim at short (1-3ms) strobe lengths. I know there's a monitor or two that doubles the strobes, but I don't want the extra artifacts/lag.
Re: Any really bright (> 450 cd/㎡) strobed monitors?
Eizo fg2421 but i hate crosshatching on it (seen on all bright colors).
More, probably some asus with gsync. Why you need it so bright? CRT are often much less bright (especially used). In terms of motion clarity the fastest lcd is still not close to CRT, some special lcds (like Benq, Asus rog) are close in input lag but still CRT is better (if using analog connection having 0 lag).
Instead looking for brightness I would ask for image quality, which lcd is closest to quality CRT? Maybe some eizo coloredge cx or not true? (that is what some seller suggested me but I couldn't see it myself). Of course it is slow.
