Any XL2730Z users with a Mstar ISP programming device or who have the old Linux Ubuntu flashrom drives still?
Can someone try to see if Ubuntu can identify the flash chip in a XL2730Z, or if the Mstar ISP device can detect or read the flash chip? (the software is still on the blurbusters main site under DIY Upgrade V2).
The mstar ISP device: http://www.yoycart.com/Product/52781882 ... ment_tool/
VGA or DVI port will work.
Basically follow the good old instructions on page 21 here:
http://forums.blurbusters.com/viewtopic ... &start=200
Stop at this command and see if you get an error.
sudo ./flashrom -p mstarddc_spi:dev=/dev/i2c-1:49 <----# identify flash chip, on bus 1 (/dev/i2c-1) at address 0x49. Change the 1 to a 0 if you are on bus 0.
XL2730Z users : Can you test something for me please?
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
