Hello
using 144hz monitor
but test ufo shows only 60
searched alot found nothing need to fix this
144hz monitor
144hz monitor
- windows refresh rate.png (55.03 KiB) Viewed 5088 times
- test ufo.png (72.19 KiB) Viewed 5088 times
Re: 144hz monitor
1) use chrome, not internet explorer.
2) hw acceleration must be enabled in the browser.
And please don't use the XL2720Z ICC file! The color presets for the xl2720z are drastically different from the XL2411z. The Xl2720Z is a 27" panel.
Re: 144hz monitor
Falk, how could you tell they were using the XL2720Z ICC file?
Re: 144hz monitor
if you scroll down in his image, the file name is at the bottom.
For one thing, the XL2720Z does not drop in gamma as the refresh rate is increased. The XL2411z (as well as many other 24" AUO TN models using this panel) does. And some reviews have shown that the XL2411z's default color low level presets may be worse than the discontinued XL2420Z.
Re: 144hz monitor
ah didn't realize there were two separate images. Was confusing. I see it nowFalkentyne wrote:if you scroll down in his image, the file name is at the bottom.
Re: 144hz monitor
Hi Falkentyne,Falkentyne wrote:if you scroll down in his image, the file name is at the bottom.
Do you have or know where to get a good ICC profile for the XL2411Z? I've been using the XL2420Z as well, I can't remember from which website I got but it was from a monitor reviewing one and it looks MUCH better but if there was a better calibrated one I'd gladly take that!
- lexlazootin
Re: 144hz monitor
ICC profiles only work in Windows and not games sadly if you didn't know
Although i don't know where you can get one or how far off your monitor is but using the windows calibration and using this site http://www.lagom.nl/lcd-test/contrast.php you can actually do a pretty reasonable job. Just make sure it's in sRGB mode when you begin.
Re: 144hz monitor
I will do that. Thanks, how do I make sure it's in sRGB mode though? On Windows' Color Management?lexlazootin wrote:ICC profiles only work in Windows and not games sadly if you didn't know
