I suggested this (hopefully) comprehensive check list of options on PC Part Picker Forums. Apart from the standard, resolution, response time, refresh rate and brightness.
Would be helpful, if someone can include any essential points missed here.
More Monitor Filters for Pros
https://pcpartpicker.com/forums/topic/1 ... s-for-pros
Code: Select all
• Display surface type: Matte or Glossy
• Panel types: OLED, AMOLED, AH-IPS, IPS, TN, VA, Quantum Dot etc
• 4K display scaler (video processing chip): MST (Multi Stream Transport) or SST (Single Stream Transport)
• 5K Tiled Display: Yes or No
• Viewing angle in degrees: range slider
• Input Lag: Range slider
• Panel Bit Depth: 8bit, 10 bit, 8+FRC etc
• Look-up table (LUT): 8, 10, 14, 16, 3D LUT etc
• PPI: range slider Eg: Retina
• SRGB coverage: Percent Range slider
• Adobe RGB Coverage: Percent Range slider
• DCI-P3 Digital Cinema: Percent Range slider
• Blur reduction (backlight strobing): Yes or No
• Pulse-width modulation (PWM) brightness control: Yes or No
• Factory Calibrated: Yes or No
• Calibration software included: yes or no
• Calibration device included: yes or no
• Display Port version numbers: 1.2, 1.4 etc
• HDMI version numbers: 1.4, 2.0 etc
• Power consumption ON: Range slider in watts
• Power consumption Standby: Range slider in watts
• Weight with stand: Slider in Kilograms
• Weight without stand: Slider in Kilograms
• Hood included: Yes or No
• Panel OEM makers: LG Display, Samsung Display, Sony Professional Display, Japan Display Inc., Panasonic Liquid Crystal Display Co., Ltd, AU Optronics, Acer
• Controls: Joystick, touch, front, rear, push button, etc
• User preset profile buttons: Yes or No
• Chassis Colors: Option boxes for popular colors
• Stand colors: Option boxes for popular colors
• Stand height Adjustable: Yes or No
• Stand height: Slider in cm
• Stand forward tilt angle: slider in degrees.
• Stand rear tilt angle: slider up to 90 degrees
• Stand left, right, pivot: Yes or No
• Stand cable management: Yes or No
• Quick Release Stand Design: Yes or No
• USB Hub: 2.0 or 3.0
• USB-C: Yes or No
• USB charging port: Yes or no
• Bluetooth Audio: Yes or No
• PSU: Internal or External
• Warranty: Years slider
