Monitor for Xbox One and PC
Hello, I'm looking for monitor/tv for Xbox One and PC, mainly for games. A few days ago I bought BENQ RL2755 and already refunded this because it has a lot of ghosting and it's very uncomfortable for me, I was trying to change AMA for off/premium/high but one by one makes it worse. I can spend for that something around 300£ and what you think guys, what's gonna be better for PC/XBOX; monitor or tv? All I need is playing smoothly without any ghosting and shit like this.
- lexlazootin
Re: Monitor for Xbox One and PC
You are probably better off buying a cheap 144hz 'gaming' monitor from Acer and Asus because no one really makes 60hz low latency gaming monitors from what i've seen besides Benq and the Benq one are pretty bad from previous experience.
Which one you can propose?lexlazootin wrote:You are probably better off buying a cheap 144hz 'gaming' monitor from Acer and Asus because no one really makes 60hz low latency gaming monitors from what i've seen besides Benq and the Benq one are pretty bad from previous experience.
Acer GN246HL has high overdrivelexlazootin wrote:You are probably better off buying a cheap 144hz 'gaming' monitor from Acer and Asus because no one really makes 60hz low latency gaming monitors from what i've seen besides Benq and the Benq one are pretty bad from previous experience.
This is not better?
ASUS VG248QE
ASUS VG248QE
ASUS VG248QE is decent monitor. But I'm not sure how it performs at 60Hz.Tyrese wrote:This is not better?
ASUS VG248QE
This one is better? Acer GN246HL
Acer GN246HL is bad decision. Asus VG248Q is better for 144Hz and 60Hz for sure.Tyrese wrote:This one is better? Acer GN246HL
so this asus gonna be the best decision for 300 pounds ye?
I don't know.
All these monitors are basically the same, anyway.
If all you care about is 60hz you might as well get a monitor that can give you more options, like backlight strobing.
As far as overdrive, the VG248QE (Tracefree=60) and the Benq XL2720Z have near perfect overdrive without strobing, but the XL2720Z requires exploiting a firmware profile bug to get it. After exploiting the profile bug, it will look comparable to the VG248QE with tracefree=60. If you can handle messing with profiles and setting blur reduction on then switching profiles to make it work, the XL2720Z will probably make you happy. The overdrive is atrocious by default with blur reduction disabled (looks worse than MBR On+AMA Premium) if you don't exploit the profile bug.
We can't tell you what's best. It's up to you and you only, based on what features you want.
