I have 3 1080p Asus monitors and one 4k sceptre TV. I get microstuttering ALL THE TIME. Every ~10 seconds, all graphics stop for less than a fraction of a second and then continue. My only remedy is to remove the tv from the graphics card. This is a new gtx 1080 rog strix running on a i7 3930k system. I am fairly certain I am good hardware wise. As soon as a I pull the tv from the card, the issue ceases. Now you can probably name near about just anything and I have tried it, OC the monitors, OC the card, turn MEMC on/off on the tv, separated the HDMI cable from the tvs AC cable, used Timer Tool to adjust yadda yadda yadda. Every little thing does nothing at all.
I am grasping at straws here now. Maybe you guys have some ideas to throw at me.
Microstuttering in everything video related!
Re: Microstuttering in everything video related!
idea is name your os.
"all graphics stop" - while in game? while watching video? even at os cursor stutters? only 1 monitor & tv gives microstuttering?
Does this happen when only the TV is plugged in?
Everything. Video, games, cursor.Q83Ia7ta wrote:idea is name your os.
Yes, only when TV is plugged in.Sparky wrote:Does this happen when only the TV is plugged in?
I mean when it is JUST the TV and nothing else.uvbeenzaned wrote:Yes, only when TV is plugged in.Sparky wrote:Does this happen when only the TV is plugged in?
So I just did another test since you made me think of trying different combinations. I hadn't gone this far yet.Sparky wrote:I mean when it is JUST the TV and nothing else.uvbeenzaned wrote:Yes, only when TV is plugged in.Sparky wrote:Does this happen when only the TV is plugged in?
- All monitors plus tv: stuttering
- All monitors no tv: no stuttering
- 2 monitors plus tv: seems to stutter occasionally maybe but not that much
- 1 monitor plus tv: no stuttering
This surely can't be a PCIe bandwidth issue. This was happening with my old R9 290x when I had it. Something else must be going on.
Code: Select all
Summary
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 3930K @ 3.20GHz 43 °C
Sandy Bridge-E 32nm Technology
RAM
48.0GB DDR3 @ 666MHz (9-9-9-24)
Motherboard
Supermicro X9SRA/X9SRA-3 (SOCKET 0) 36 °C
Graphics
ASUS VS239 (1920x1080@60Hz)
U505CV-UMC (3840x2160@60Hz)
NVIDIA GeForce GTX 1080 (ASUStek Computer Inc) 40 °C
Storage
238GB M4-CT256M4SSD2 (SSD)
2794GB Seagate ST3000DM001-9YN166 (SATA) 31 °C
698GB Seagate ST3750330NS (SATA) 32 °C
Optical Drives
TSSTcorp CDDVDW SH-222AB
Audio
Logitech G933 Gaming Headset
Operating System
Computer type: Main system chassis
Installation Date: 11/16/2016 9:24:38 PM
