Is this monitor any good?
crippotheone
Post by crippotheone » 19 Dec 2016, 04:21
I found a really good Dell Professional P2012H Monitor
http://www1.la.dell.com/vc/en/corp/peri ... 12h&s=corp
Though i have to know if it's any good or worth getting,The pivot feature isnt something i really need but is it good for games?
lexlazootin
Re: Is this monitor any good?
Post by lexlazootin » 19 Dec 2016, 07:23
No one is going to know the actual answer to your question because no one here would have that monitor. To be honest, it's kinda bad in the specs department. 1600x900 (Not even full HD 1080p), TN, 20inches (Quite small compared to other monitors) but on the other hand Dell does typically do a pretty good job with input lag so for gaming it won't be that bad.
How much can you get it for?
Post by RealNC » 19 Dec 2016, 12:01
Resolution is fine for this size. It's exactly the same as a 24" 1080p (which is 91 DPI).
But you should seriously consider getting a bigger one. 20" widescreen is very, very small. A 20" 4:3 or 5:4 might be big, but 20" 16:9 is tiny.
crippotheone
Post by crippotheone » 20 Dec 2016, 04:15
lexlazootin wrote:No one is going to know the actual answer to your question because no one here would have that monitor. To be honest, it's kinda bad in the specs department. 1600x900 (Not even full HD 1080p), TN, 20inches (Quite small compared to other monitors) but on the other hand Dell does typically do a pretty good job with input lag so for gaming it won't be that bad.
60 euro which is kinda good.Currently i have a FLATRON L1918S and to be honest im tired of having it since it's not really confortable to the eyes but i would any other suggestions on cheap monitor's that are on the market
crippotheone
Post by crippotheone » 20 Dec 2016, 04:24
Tbh im i really don't mind resolutions besides if it's small and has a sharp image then im completely fine because i got tired of my 5:4 monitor
Post by RealNC » 20 Dec 2016, 11:47
As I said, the monitor is very small. Your L1918S is actually much bigger.
You can get a 24" for about €100 to €120. Why not go for that? Like this:
http://www.newegg.com/Product/Product.a ... 6824260487
or this:
http://www.newegg.com/Product/Product.a ... 6824009422
crippotheone
Post by crippotheone » 21 Dec 2016, 04:36
RealNC wrote:As I said, the monitor is very small. Your L1918S is actually much bigger.
or this:
though small monitors arent better because they fit better in the eyes?
Also my monitor is big but small resolution and a rather bad aspect ratio which seriously puts lets say the hud to the far corners
which is really annoying some times if the games made have pretty bad huds
