I bought this monitor from a buddy and it was fine when i looked at it and he said it was fine but for me it looks absolutely terrible. It isnt sharp at all, blues turn purple, etc.
I tried tweaking settings as advised by YouTube but not much changed. Any ideas?
This is the original picture:
Normal color https://imgur.com/gallery/etuvo
This is my monitor:
https://imgur.com/gallery/OS1lj
Benq 2730z horrible colour. Fix?
Re: Benq 2730z horrible colour. Fix?
change preset from fps1 to some other and i wont help then try different color values (R, G, B)
This panel has a low level panel bug. Sometimes the panel just dies. The same issue happens to the Asus ROG Swift, which uses the EXACT Same panel, but with a different part number due to Asus bezel specifications. Someone on Hong Kong had an Asus repair service when their panel did the exact same thing and they actually replaced the GSYNC MODULE and the ELECTRONICS first--but the problem still remained. Then they replaced the actual LCD itself and everything was perfect.
RMA.
RMA.
Yeah i tried all presets and tried some of the rgb that Google recommendedQ83Ia7ta wrote:change preset from fps1 to some other and i wont help then try different color values (R, G, B)
