Benq xl2411z cant get higher than 60hz even with dvi dual
Everything about displays and monitors. 120Hz, 144Hz, 4K, 1440p, input lag, motion tests & TestUFO, monitor decisions, and more. Questions? Just ask!
Postby flumine » 08 Jan 2017, 15:00
Hi, I disassembled my pc to clean it and after I rebuilt it and I've got a problem that my monitor can't reach more than 60hz. I'm sure I'm using dvi dual channel. I reinstalled gpu drivers but it didn't help, I have reset dispay with CRU, nothing. before disassembling I had my 144hz. Now, amd catalyst says that I can get only 120hz on 1024x768 like on vga port, but I'm using dvi d port on my gpu now
flumine
Re: Benq xl2411z cant get higher than 60hz even with dvi dua
Postby RealNC » 08 Jan 2017, 17:10
Try another port. Some cards with multiple DVI ports have a SL-DVI one.
Postby flumine » 08 Jan 2017, 23:34
RealNC wrote:Try another port. Some cards with multiple DVI ports have a SL-DVI one.
The second one is VGA port, even above of this port there's written that it's VGA .
flumine
Postby flumine » 08 Jan 2017, 23:37
My gpu is asus matrix r9 280x
flumine
Postby flumine » 09 Jan 2017, 00:17
I fixed. The problem was in button on gpu that changes between single link and dual link. probably I accidentally changed on disassembling
flumine
Postby Q83Ia7ta » 09 Jan 2017, 03:06
I didn't know AMD makes so funny hardware buttons :]
Q83Ia7ta
Postby lexlazootin » 09 Jan 2017, 03:13
u what mate? that can't be real.
lexlazootin
Postby flumine » 09 Jan 2017, 05:25
lexlazootin wrote:> button on gpu that changes between single link and dual link
it's real. My gpu is Asus rog matrix r9 280x. There's one dvi-i port is connected to displayport, and if you want that this displayport works you should change dvi-i to single link or if you need dual link, just change it with button on gpu, but displayport will not work
flumine
Return to General - Displays, Graphics & More
Who is online
Users browsing this forum: Google [Bot] and 6 guests
