EDIT : Ive just read something about VT, while trying to find which Display mode is the most recommended, where you said NOT to touch the modes after vt tweaking.. Bcuz it distrupts the image and can even cause damage.. So what I just leave it at standard mode and then tweak?Falkentyne wrote:"Exploiting" means "taking advantage of...." or using it.
Don't think too much.
Just wait until you get the monitor and start using it. It's really EXTREMELY simple.
& also, I was reading about the pixel clock patcher via MonitorTests and also a in ur sticky since I always use DVI, and I didn't quite fully understand, ToastyX wrote that it allows higher resolutions and refresh rates in the Nvidia driver, is he referring to a "higher" custom one because what u said about tricking the monitor into calculating strobes as for a 1440p ? is that why I need a clock which is higher than 330mhz?
