RealNC wrote:There's also the AOC G2460PG. Normally with AOC monitors the major issue is their very bad overdrive. However, with G-Sync it's NVidia that does the overdrive implementation (it's handled by the G-Sync module,) so for this monitor it might actually be not too bad.
There's the Dell S2417DG. 1440p though. At 24" is has a VERY high pixel density. The apparent resolution is so high that you might not even need anti-aliasing anymore in games. However, the desktop is unusable without something like 150% DPI scaling enabled in Windows. And it's more expensive (but less expensive than the Asus PG248Q, which is interesting.) And playing at 1080p will probably still result in a blurry picture because of NVidia's bad GPU scaling quality (G-Sync cannot do scaling on its own; GPU scaling is the only option.) However, anything rendered at such a high DPI in the native resolution looks amazing. Not recommended without at least a 980Ti or 1070 though for modern games. Older games pose no problem, obviously. This monitor might actually be the "best bang for the buck" option simply because it's the only 24" with such a high resolution and G-Sync and 165Hz refresh rate.
Another one is the AOC AG241QG, which is also 1440p, but... it's AOC. And it's more expensive than the Dell
And I think it's worth researching the Acer XB240H. Even if you don't like Acer, it doesn't mean it's a bad monitor.
If I was going for a 24", I would probably go with the Dell. If I had a good return policy from the store I buy from, I'd try the AOC G2460PG first simply because it's the cheapest. If I wasn't satisfied, I'd return it and only then get the Dell.
I'm seeing that some of these monitor suggestions are LED. Isn't TN the better way to go since it's faster?
