striker333
Post
by striker333 » 08 May 2017, 10:08
Chief Blur Buster wrote:striker333 wrote:hi guys . i have serious problem with my 2720z specially with videos all videos even streaming videos the monitor give me judder panning that cause headache
Here's another take (theory) on why you are getting headaches.
Are you someone who hates "24fps judder" or "3:2 pulldown"?
Are you used to stuff like Sony MotionFlow on a TV?
Were you hoping your 120Hz monitor would help?
Solutions:
Fix 3:2 pulldown judder
If your problem is simpAlso, make sure you play original content. DVD and BluRay, as well as several iTunes/Netflix, can be played back in 24p avoiding the 3:2 pulldown judder. However, that will still be 24 frames per second.
Improve fluidity via upsampling framerate
If you want more than 24 frames per second in your movie, you need to get SmoothVideo Project if you want to bring interpolation (24fps -> 120fps) like "MotionFlow" to movie playback on your 120hz monitor. While this creates fake frames between the real frames, many people have often preferred this effect, as some people do get headaches at anything low-framerate no matter how perfect the frametimes are...
Download:
http://www.svp-project.org
the problem is not the headache the problem is that there is something wrong with the screen check this video plz i recorded it with mobile cam even it is noticeable from mobile cam
https://www.youtube.com/watch?v=SvPxvWN ... e=youtu.be
Falkentyne
Post
by Falkentyne » 08 May 2017, 12:03
Turn on "Single Strobe" if using blur reduction.
Make sure "Instant mode" is enabled.
Your video seems to show a video card vsync issue, not a monitor problem.
striker333
Post
by striker333 » 08 May 2017, 13:14
thx for the reply again instant mode always om i teied every single option in the screen . i dont know how to enable single strobe even dont know wht is it
but i dont use blur reduction btw . can changing the firmware fix this problem ??? besides blurbuster utility not working for me anymore the new one even
striker333
Post
by striker333 » 09 May 2017, 07:06
i made single strobe on . i have just know that u can navigate the service menu
and the utility worked but the lag still
striker333
Post
by striker333 » 12 May 2017, 06:57
i connected the monitor to a PS4 and the same problem happened but less than PC
striker333
Post
by striker333 » 13 May 2017, 09:03
i cant rma i bought is used and cant rma it in my country. i connected it to the reciever and used ntsc 1080 60hz . it didnt do that juddering lol thats weired
iam done with this monitor really
