Hello,
First of all I just wanna say I'm totally noob in this thing. Before 1 hour i even didnt know you can OC your monitor
So ,I bought this monitor cheap ,and it is second hand. Whenever i switch to 144 hz I just feel "lag" . It's not smooth. When i switch to 120 hz,the problem disappear(Yes i do have over 144 fps all the time) . Maybe the old owner did that 120 hz Blur Reduction ? I downloaded "Display Pilot" ,and it says "timing recommendation 120 hz". Is there any way i can fix it? Here's photo from Display Pilothttp://imgur.com/a/sT29r
Weird Hz Issue with XL2411Z
Re: Weird Hz Issue with XL2411Z
1. Are you running in multimonitor mode? Combining 60Hz and 144Hz monitors?
If so, try disabling multimonitor and see what happens!
2. If that doesn't work, check www.testufo.com/frameskipping --
Please take a photo of the screen and post it here!
That looks like a screenshot, not a photo. You need an actual photo, from a camera, preferably with long exposure time.
Ahm,my bad!
It says 120hz coz i switched it ,so i can play normaly.
http://imgur.com/a/ZQ48S
http://imgur.com/a/nzqBE
Maybe it needs firmware update?
