I have 109 videos in two folders. One contains 1-78, the other contains 79-109. They are all 24fps videos with names a1-a109. I want to convert them to 120fps videos b1-b109.
I want to use the following command on all of them:
ffmpeg -i a.mov -r 120 -vf "setpts=(1/5)*PTS" -an b.mov
Is there an alternative command which effectively gives this command to multiple inputs, or will I have to type the "normal" command 109 times?
Multiple files with one ffmpeg command?
Re: Multiple files with one ffmpeg command?
You can script it. For example with this command:
This will run ffmpeg 78 times, for each aN.mov file, and produce a bN.mov output, where N goes from 1 to 78.
(This assumes you're on Linux or Mac OS. This won't work on Windows.)
Code: Select all
for i in {1..78}; do ffmpeg -i a$i.mov -r 120 -vf "setpts=(1/5)*PTS" -an b$i.mov; done
I'm on Windows, so unfortunately this won't work.
Thanks for trying to help though.
Didn't test it, but on Windows you should be able to do:
Code: Select all
for /l %x in (1, 1, 78) do ffmpeg -i a%x.mov -r 120 -vf "setpts=(1/5)*PTS" -an b%x.mov
I tried this and got the following error message:
At line:1 char:4
+ for /l %x in (1, 1, 78) do ffmpeg -i a%x.mov -r 120 -vf "setpts=(1/5) ...
Missing opening '(' after keyword 'for'.
+ CategoryInfo : ParserError: (:) [], ParentContainsErrorRecordException
+ FullyQualifiedErrorID : MissingOpenParenthesisAfterKeyword
At line:1 char:4
Well, I don't know what's wrong. I just tested on Windows 10 and it works fine.
What's your ffmpeg version?
Some older versions have missing options.
Also, sometimes batch files handles things differently from command lines (such as different parsing of % or paranthesis characters), you may wish to doublecheck. RealNC, are you pasting into a command line, or pasting into a batch file?
When typing:
ffmpeg -version
it says:
ffmpeg version N-82966-g6993bb4 Copyright (c) 2000-2016 the FFmpeg developers
ffmpeg -version
it says:
I just typed it in directly in the command line. No need to make batch files for one-off uses.
True. But what someone is doing with a command line, someone else might be pasting into a batch file unbeknownst to you..
Usually it works, but weird character parsing has caught that off guard sometimes...
Let's see what OP says.
