Post
by Chief Blur Buster » 14 Sep 2017, 09:38
grizmo2 wrote:Is there 240Hz monitor with ULMB to 240hz or will it be?
For 240Hz strobing, you'll have to use BenQ/Zowie
DyAc brand rather than NVIDIA's
ULMB brand.
Currently, the latest-greatest monitor capable of 240Hz strobing is the Zowie XL2546. That said, remember that strobe crosstalk can be a bigger issue (if you're sensitive to it) the closer to the monitor's maximum refresh rate.
That said, what BenQ/Zowie lets yoiu do, is to have a choice of multiple refresh rates (strobing at a lower refresh rate with less strobe crosstalk, versus strobing at a higher refresh rate with more strobe crosstalk).
BenQ/Zowie XL2540 - 240Hz / FreeSync / MBR
-- strobes up to 240Hz
BenQ/Zowie XL2546 - 240Hz / FreeSync / DyAc
-- strobes up to 240 Hz
Acer XB252Q - 240Hz / G-SYNC / ULMB
-- strobes up to 144 Hz
Acer XB272Q - 240Hz / G-SYNC / ULMB
ASUS ROG PG258Q - 240Hz / G-SYNC / ULMB
grizmo2
Post
by grizmo2 » 14 Sep 2017, 12:16
Chief Blur Buster wrote:grizmo2 wrote:Is there 240Hz monitor with ULMB to 240hz or will it be?
ULMB brand.
Zowies Benq strobes at 240hz without any issues?
Post
by Chief Blur Buster » 14 Sep 2017, 12:53
grizmo2 wrote:Zowies Benq strobes at 240hz without any issues?
It depends on what you mean by "issues"
Since it's not "zero compromise", does "issue" mean "with acceptable compromises" or "with dealbreaker compromises" -- and this can be like the IPS-versus-TN debate, a personal preference of pros-versus-cons. Some people like the 240Hz strobe mode, and some people prefer to use a lower refresh rate for reduced strobe crosstalk.
All of the 240Hz monitors currently do relatively good job of 144Hz strobing with fewer compromises than strobing on a 144Hz monitors.
grizmo2
Post
by grizmo2 » 14 Sep 2017, 13:15
Chief Blur Buster wrote:grizmo2 wrote:Zowies Benq strobes at 240hz without any issues?
I mean it just works fine, because its interesting if 240Hz monitors can use ulmb to 200/240
ericl
Post
by ericl » 14 Sep 2017, 13:47
Holy, the BenQ XL 2546 has strobbing up to 240hz ? I would have picked that up instead of the Asus PG258q
grizmo2
Post
by grizmo2 » 14 Sep 2017, 13:49
Thats why im askin
grizmo2
Post
by grizmo2 » 14 Sep 2017, 15:54
grizmo2 wrote:Chief Blur Buster wrote:grizmo2 wrote:Zowies Benq strobes at 240hz without any issues?
If I will use benq and it will be something like 240hz + 180 scrob or just 180hz scrob? I know its hard to underesntad
open
Post
by open » 14 Sep 2017, 16:26
ericl wrote:Holy, the BenQ XL 2546 has strobbing up to 240hz ? I would have picked that up instead of the Asus PG258q
That can be a good option if you can always maintain over 240fps. I've tried playing on 240hz vsync off gsync off and there is still a noticeable stutter with 240hz when fps drops below 240fps. If benq made a gsync screen I would probably have bought that but ever since i played on my dads bright ass DLP tv I love bright screens with low response time and the pg258q is the brightest by far. There was just something about that DLP. It's been a while now but it felt like it had no motion blur at all.
