Looking for guide
Looking for guide
So i was looking to buy a monitor and there are so many so i was looking if there was a guide that makes things simple because i want a monitor that responds fast because i play fps games only(+ pubg) and if it would be cheap. I am buying from Europe.
- lexlazootin
Re: Looking for guide
Acer GN246HL
144hz
$190~
AOC G2460PF
144hz Free-Sync
$200~
AOC G2460PQU
$200~
AOC G2460FQ
$200~
Acer XFA240
144hz Free-Sync
$210~
Acer XF240H
144hz Free-Sync
$220~
Nixeus NX-VUE24A
144hz
$230~
Asus VG248QE
144hz
$260~
144hz
$190~
AOC G2460PF
144hz Free-Sync
$200~
AOC G2460PQU
$200~
AOC G2460FQ
$200~
Acer XFA240
144hz Free-Sync
$210~
Acer XF240H
144hz Free-Sync
$220~
Nixeus NX-VUE24A
144hz
$230~
Asus VG248QE
144hz
$260~
from where and is the cheap one good ?
- lexlazootin
Idk where from? i thought you would know since you live there I find it pretty good if you just type the model number into google and hit the shopping tab, works pretty good for me anyways.
A monitor is just a PCB board and a panel, if all you care about is playing game they will be fine. The more expensive ones just have newer panels, IPS, higher resolution and/or G-Sync. Newer panels can look better.
To support the continued improvement of Blur Busters, I do recommend fellows to buy monitors through our US Amazon links:lexlazootin wrote:Idk where from?
Blur Busters links to Amazon.com
- Official List of Best Gaming Monitors
- List of G-SYNC Monitors
- List of FreeSync Monitors
Blur Busters links to Amazon Europe or Canada
If you're buying from another Amazon other than .com:
-- Select one of: Amazon UK | Germany | France | Spain | Italy | Canada
-- Search for monitor model, add what you need to cart, and buy
You're certainly welcome to buy from somewhere else, but just wanted to make sure y'all were aware!
Much appreciated!
