27" WQHD 144Hz+ IPS
grizmo2
27" WQHD 144Hz+ IPS
Post by grizmo2 » 17 Sep 2017, 17:01
Welcome, looking for 27" WQHD 144Hz+ IPS(really good true colours) Budget is unlimited
Re: 27" WQHD 144Hz+ IPS
Post by jorimt » 17 Sep 2017, 17:37
FreeSync, G-SYNC, or non-VRR?
Off the top of my head, the two best 1440p 27" IPS G-SYNC models are:
Acer Predator XB271HU:
https://www.amazon.com/dp/B0173PEX20?tag=blurbust-20
ViewSonic XG2703-GS:
https://www.amazon.com/dp/B01LWJMM1S?tag=blurbust-20
Both have the same panel, but each have different aesthetics. A plus to the XB271HU (which I own) is it has a built-in refresh rate meter, not sure if the ViewSonic does.
Backlight bleed severity will vary per unit, even for the same models.
Post by RealNC » 17 Sep 2017, 22:22
jorimt wrote:A plus to the XB271HU (which I own) is it has a built-in refresh rate meter, not sure if the ViewSonic does.
It doesn't.
