Hello, sorry for my bad english.
Some months ago i buy my first 144hz monitor ACER KG251Q, i don't know what is name of my issue, i call him color problem..
i know it is normal that from nvidia conrol panel setting i can not get above than 60hz on HD Resolution and when i set PC resolution i can set 144hz but in this case i have color problem...
Comparison to Nvidia HD Resolution vs PC Resolution:
PC Resolution: youtu.be/AxKGAwSrctA
HD Resolution: youtu.be/l6KHT2QdIDQ
PC Resolution: imgur.com/CvH3M0g
HD Resolution: imgur.com/XYTizep
Together: imgur.com/5qC4zf5
VIDEO: youtu.be/4rm7HzK2zh0
acer kg251q
Re: acer kg251q
someone can tell me what is exactly difference betwen nvidia HD(1080P, 1920x1080) vs PC(1920x1080) resolution settings?
then i will creating same resolution according to nvidia hd resolution settings, through custom resolution setting..
Re: acer kg251q
HD for TV connected, PC for Monitor.
at imgur.com/5qC4zf5 looks like photos done at different view angles
Or there is different font rendering (different pixel smooth technique). It differs because of different subpixel layout http://www.lagom.nl/lcd-test/subpixel.php
Re: acer kg251q
I just watched videos. It's more looks like that overdrive acts differently at 60hz and 144hz. I've met that acer has overdrive artifacts even at static (still) picture. Here is your issue im sure - viewtopic.php?f=2&t=5592
Re: acer kg251q
thanks for replys.
i found what causes issue.. 1) if i decrease G Gain & G Bias from color temp seeting problem is solved. 2) also from color temp, if i change color temp to Cool mode instead Warm/Normal, problem again solved. 3) if i set brightness less than 47 level, problem solved..
I never think that it was possible to solve issue from monitor setting.. because 'HD' resolution was fine. and 'PC' resolution had issue at same monitor settings..
