What settings for Asus VG259QM 240hz vs 160~fps
Posted: 01 Apr 2020, 11:11
Hello,
I already bought this Asus version of 24 inch - VG259QM, I waitng for deliver for now.
I really hope the version of VG259QM will not be worse compare to 27 inch (VG279QM ), because I already found that 27 inch has wider gamma. Hopefully thats only downside, I really want faster version like these 27 inch with low input lag and fast response time
I got questions though.
I heard that best is to set
I play Call of Duty Warzone and even with 1080ti aorusu + 8700k after OC, my avg fps is 160~
So actually I should use 60overdrive, 240hz? or maybe use 280hz (to have lower lag + overdrive at 60 + cap fps around 160 to have stable frame rate)
Also, do I need to run G-sync + v sync in NVCP? And what about FPS cap? because for sure I will not run over 240hz, so maybe in this case I do not need to cap the fps ?
This one guy said that
I got 8700k OC 4,9GHZ and 1080ti AORUS
"-strobing + VRR + overdrive 60 with the framerate capped at 200fps so there's not *too* much frame variation.
If it comes to the Hz I know that 240hz is most stable and best option + overdride in OSD for 80, but after I read that I believe if my fps will be around 120-200 fps range the best will be 60 right?tftcentral seem to conclude that setting the overdrive to 80 is the best choice if your framerate will be in the 200-280 hz/fps range when using VRR and strobing at the same time on this monitor, and 60 if in the 120-200hz/fps range, and finally 40 if in the 60-120hz/fps range in the game and/or at the quality settings you choose to play at the time,"
So maybe I should actually cap it to hold stable fps? Im consufed, because when I have avg 160 fps I already have almost 90+% GPU Usage which gives a lot of input lag(that is what I heard). So in this case it is actually better to have 144hz monitor instead of 240hz. Im so confused"-strobing + VRR + overdrive 60 with the framerate capped at 200fps so there's not *too* much frame variation.
