so i received this monitor yesterday and am confused as shit with all the different options in the OSD settings. while i think it's awesome to have all these different options, i don't know what most of these settings even do lol
what are the optimal settings to use 240Hz and 1ms? if i recall correctly, i remember reading a post from Chief Blur Buster stating the optimal settings and even went further in details as to what mouse dpi to use too. unfortunately i can't find that post and was wondering if someone knew what it was or has the link for it? i've skimmed through the forums and couldn't find anything, or if i did, they were on 100-144Hz.
Optimal Settings for XG270
Re: Optimal Settings for XG270
For end users, the easiest options to remember are:june wrote: ↑17 Jun 2020, 17:11so i received this monitor yesterday and am confused as shit with all the different options in the OSD settings. while i think it's awesome to have all these different options, i don't know what most of these settings even do lol
Easy Modes
(1) For FreeSync / G-SYNC use, you should use 240Hz (default) with FreeSync ON
(2) For PureXP+ latency priority, use 240Hz (default) with PureXP+ ON
(3) For PureXP+ motion quality (clearest motion), use 120Hz with PureXP+ ON
Slightly Improved Modes
For better overdrive, use 224Hz in place of 240Hz via NVIDIA Control Panel -> Custom Resolution, combined with maximum overdrive (ViewSonic overdrive is low-aggressiveness by default, and looks very good at 224Hz).
Mouse Microstuttering Reduction for Motion Blur Reduction Technologies
For Mouse DPI, see: "Fixing Amplified Microstuttering Visibility From Blur Reduction":
viewtopic.php?f=4&t=3555
.........Set Middle speed setting in "Set a pointer speed" in Control Panel
.........Set Reasonably high DPI in Mouse Vendor Software (1600dpi+ recommended for strobe technologies)
.........Set Low Sensitivity in Game Menus (to compensate for super-high DPI)
For reliable high-DPI operation, make sure you're using recent high-quality mouse sensor, accurate mouse pad, and good non-damaged mouse feet. By adjusting these settings, your mouse slow-speed turns and medium-speed turns will be much smoother (CRT motion clarity).
This will be coming in a HOWTO very soon this month.
thanks so much!Chief Blur Buster wrote: ↑17 Jun 2020, 17:33For end users, the easiest options to remember are:june wrote: ↑17 Jun 2020, 17:11so i received this monitor yesterday and am confused as shit with all the different options in the OSD settings. while i think it's awesome to have all these different options, i don't know what most of these settings even do lol
Easy Modes
if i'm trying to use "Easy Mode #2" (PureXP+ latency priority), should i put light, normal, extreme, or ultra under PureXP+? I've realized that the settings on the monitor itself give me all those aforementioned options, but in the program i've downloaded, "Elite Display Controller", it only gives me On or Off option. should i just use the program and click On?
Adjust that to personal preference.
It’s a clarity-vs-brightness tradeoff (much like ULMB Pulse Width or DyAc Strobe Duty / Persistence). Brighter but slightly more blur, darker but slightly less blur.
I am looking for the optimal or best settings for this monitor. For shooter games. maybe someone can give me the best settings for the monitor itself.
