Hi everyone!
I am looking for a replacement BenQ XL2546 panel but I cannot seem to find the exact panel number I've checked on https://www.displayspecifications.com/en/model/f24cb92, and it does not seem to show you the panel model.
I found out that the BenQ Xl2540 uses the M250HTN01.3 panel.
But I can't find anything on the XL2546 Panel. The only difference between those 2 monitors is the brightness (400 vs 320). Would using the M250HTN01.3 work on the XL2546?
What is the BenQ XL2546 Panel model?
Re: What is the BenQ XL2546 Panel model?
Moved to more appropriate section.
Hi there! Did you manage to find which auo panel model the zowie xl2546 uses? I'm in the same boat as you as I can't seem to find anything on the Internet about it. Any help would be great, thanks.
The XL2546 uses the Q250HTN00 A000.jorrell279 wrote: ↑16 Jun 2021, 09:25Hi there! Did you manage to find which auo panel model the zowie xl2546 uses? I'm in the same boat as you as I can't seem to find anything on the Internet about it. Any help would be great, thanks.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
thanks a lot man
