Asus TUF VG259QM Perfect Calibration
I__x__0
Post by I__x__0 » 06 Nov 2020, 04:32
You get perfect black and colors with this settings.
Download and apply this ICC Profile:
https://www.tftcentral.co.uk/icc_profil ... g279qm.icc
GameVisual: Racing Mode
ShadowBoost: OFF (It's your choice)
Overdrive: 80 (it's your choice)
Brightness: 60
Contrast: 80
VividPixel: 25
Colors: User
Red: 97
Green: 94
Blue: 97
Nvidia Settings:
Brightness: 45%
Contrast: 47%
Gamma: 0.99
Digital Vibrance: You can put it 100% if you play CS GO, the colors are perfect
In the game just up brightness and you get perfect colors and visibility. (You don't need ShadowBoost, just boost the brightness from the game)
I play with this settings also in Warzone, just turning on ShadowBoost to level 1, sometimes level 2.
cutecumbber
Re: Asus TUF VG259QM Perfect Calibration
Post by cutecumbber » 03 Jun 2021, 01:02
Thank you so much I was going crazy knowing something was off when I play CSGO after hours of testing I figured why the reason that the color black isn't dark enough anyways thanks so much
cutecumbber
Post by cutecumbber » 03 Jun 2021, 01:26
What is Vivid Pixel? what does it do? I heard it has input lag on Acer monitors.
Thank you so much for the ICC profile!
HolaSoyDomy
Post by HolaSoyDomy » 04 Dec 2023, 17:55
I think that the best configuration for the overdrive is not 80 but 120, which is a hidden configuration of the monitor, it is the one with the least input lag, you can check it in rtings
indicatered
Post by indicatered » 21 Mar 2024, 07:14
how do you download the ICC profile when i click it doesn't do anything
Post by RealNC » 23 Mar 2024, 05:23
indicatered wrote:
21 Mar 2024, 07:14
Maybe right-click and select "save link" (or similar, on Firefox it's called "Save Link As...")
