Here is timing of mine BenQ XL2411T (first revision):
Code: Select all
Detailed timing #2....... 1920x1080p at 120Hz (16:9)
Modeline............... "1920x1080" 285,500 1920 1968 2000 2080 1080 1083 1088 1144 +hsync -vsync
Detailed timing #4....... 1920x1080p at 144Hz (16:9)
Modeline............... "1920x1080" 317,490 1920 1944 1976 2008 1080 1083 1088 1098 +hsync +vsync
Code: Select all
Detailed timing #3....... 1920x1080p at 144Hz (16:9)
Modeline............... "1920x1080" 325,080 1920 1944 1976 2056 1080 1083 1088 1098 +hsync +vsync
Code: Select all
Code: Select all
Modeline............... "1920x1080" 346,500 1920 1968 2000 2080 1080 1083 1088 1157 +hsync -vsync
Detailed timing #5....... 1920x1080p at 170Hz (16:9)
Modeline............... "1920x1080" 414,250 1920 1968 2000 2080 1080 1083 1088 1172 +hsync -vsync
Detailed timing #6....... 1920x1080p at 180Hz (16:9)
Modeline............... "1920x1080" 441,000 1920 1968 2000 2080 1080 1083 1088 1178 +hsync -vsync
About DVI Splitter
https://www.dx.com/p/dir-016-dvi-male-t ... -cm-229850
