List of monitors that do 1440p@120Hz on XB1X?
Does one exist?
Re: List of monitors that do 1440p@120Hz on XB1X?
No and doubt it could run that anyway.
See www.blurbusters.com/freesync/list and check the 1440p section.
They still can do both 1440p 60fps and 1080p 120fps.
Hi Chief. Would you be able to look at this post that I made about the LG 27gl650 monitor? I just purchased it, but after looking at this site I'm not sure if it is the best for my purposes--mainly input lag and motion blur on both PS4 slim and Xbox One S. While also considering upgrading to the new Xbox in a new or so. Thanks.Chief Blur Buster wrote: ↑28 May 2020, 14:44See www.blurbusters.com/freesync/list and check the 1440p section.
viewtopic.php?f=21&t=7216
acer XG270HU Can do 1440p, 120hz and freesync
I found good recommendations here, thanks!
