Reflex Latency Analyzer API
The new Reflex monitors (e.g. AW2521H) provide the possibility to measure system latency and display it on the OSD after each click. However, gathering a large sample size is extremely time-consuming due to having to manually gather and process the samples (recording video with phone / writing down values in real-time + processing it afterwards). Has an experienced developer checked whether it's possible to write a very light-weight tool that accesses the register the OSD latency value is stored in after each click and ultimately dumps all values to a file once you're done gathering the target sample size? In combination with onboard mouse macros, this would enable fully automated testing.
Starting point for beginners: PC Optimization Hub
Re: Reflex Latency Analyzer API
I have both an LDAT and a Reflex Latency Analyzer-capable monitor (PG279QM), and was also surprised to find there wasn't any such tool available to log or aggregated the captured data with the latter, whereas the LDAT indeed already does include such software.Brainlet wrote: ↑16 Oct 2021, 23:49The new Reflex monitors (e.g. AW2521H) provide the possibility to measure system latency and display it on the OSD after each click. However, gathering a large sample size is extremely time-consuming due to having to manually gather and process the samples (recording video with phone / writing down values in real-time + processing it afterwards).
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
