Flicker on 271QRX (not typical)
Gandi
Post by Gandi » 14 Apr 2024, 01:43
Hello!
My friend has recently bought MSI 271QRX and heexperiences some weird flicker that I have never seen before It doesn't look like classic near black OLED/LG flicker
Video attached: https://streamable.com/sjdlyk
Settings used: 360 Hz, G-Sync On, V-Sync On in control panel
Bad cable? Tried different DPs and HDMIs
Bad monitor firmware?
Re: Flicker on 271QRX (not typical)
Post by RealNC » 14 Apr 2024, 09:58
Turn off overdrive in the monitor OSD and see if that helps. It's recommended to disable overdrive anyway with his display.
Gandi
Post by Gandi » 14 Apr 2024, 10:41
RealNC wrote:
14 Apr 2024, 09:58
Can't find it in monitors settings? Are you sure?
Post by RealNC » 14 Apr 2024, 12:32
Gandi wrote:
14 Apr 2024, 10:41
I was going by what the rtings review said, which is "Recommended Overdrive Setting: No Overdrive". I misunderstood that as a recommendation to disable overdrive. But apparently what it means is that this display has no overdrive.
