Blur Busters Forums
Which adapter I need to buy ?
Tell us suggestions about improving Blur Busters Forums. This includes this forum and other parts of Blur Busters.
Postby espe89 » 26 Jul 2015, 07:49
Hello everyone,
Sorry for my poor english, (I'm French :p)
I have an issue with my setup, I cant run 120hz on my iiyama g2773hs.
This monitor always worked with 120hz signal on my gtx 670 SLI (Plugged with DVI) then I decided to upgrade GPU and monitor for 1440p.
So I'm now with my Qnix 2710 @ 100hz 1440p on the only one DVI out I got on my EVGA gtx 980Ti SC2.0, I have 3 other DP outs but the only way to have 120hz working on the iiyama is DVI (like the Qnix).
I know there is a lot of adapters, I know I will need an active one, but I dunno if this one will work :
http://www.amazon.fr/StarTech-com-DP2DV ... VI-D+Actif
Anyone here got the same problem and solved it with an adapter ?
Thanks
Second question :
I cant go more than 100hz with my qnix @ 1440p, but I dont understand why I cant go 120hz @ 1024*768 (for CS:GO)
espe89
Return to Forum Help & Suggestions
Who is online
Users browsing this forum: No registered users and 1 guest
