OSD says 60hz only
Everything about displays and monitors. 120Hz, 144Hz, 4K, 1440p, input lag, motion tests & TestUFO, monitor decisions, and more. Questions? Just ask!
OSD says 60hz only
Postby x0rr » 12 Feb 2016, 17:57
Hi Guys,
recently I got my benq xl2411z and I used to play cs:go at 1440x1080. So i created with cru a 1440x1080@120 HZ with 1350 VT tweak for more brightness. But now i am not sure if i am actually running @120hz because in the OSD it says Current resolution: 1440x1080@60Hz.
but in windows resolutions it says 120Hz and on testufo.com i am also getting 120fps.
Also i am noticing the difference between 1440x1080 and 1920x1080 - the first one is much brighter even tho i tweaked the 2nd res.
I hope u understand my problem and can help me. sorry for my bad englisch i am not a native speaker.
my system:
win7 64bit
amd fx 6300 cpu
amd r9 270x gpu
benq xl2411z connected with the dual link dvi cable at the 1st port of my gpu
x0rr
Re: OSD says 60hz only
Postby Q83Ia7ta » 12 Feb 2016, 18:08
It's ok (OSD saying 60Hz) for BenQs with non-standard timings. Just google copy-paste to google search "site:forums.blurbusters.com benq vt trick osd 60hz"
Q83Ia7ta
Postby x0rr » 12 Feb 2016, 18:21
ah goood to know. so i am actually running @120hz right?
ty for the quick reply.
x0rr
Postby Q83Ia7ta » 12 Feb 2016, 19:07
x0rr yeah u r running 120hz
Q83Ia7ta
Postby x0rr » 13 Feb 2016, 19:45
tyvm for quick help
#close
x0rr
Return to General - Displays, Graphics & More
Who is online
Users browsing this forum: Bing [Bot] and 3 guests
cron
