ASUS vg248qe after lightboost
caseyohrn
Re: ASUS vg248qe after lightboost
Post by caseyohrn » 14 Sep 2017, 01:06
If a window from a browser is open for too long that part of the screen will be affected. It's not just a single line, but can also be square shaped and sometimes words, buttons & icons will be retained.
It has to be one of those two parts from my results of unplugging all the cables and doing the burn-in test from the service menu and instantly seeing no burn-in. Upon plugging the monitor back in using Display Port & HDMI the retention returned immediately in the same spots.
The day I get the parts I'll burn-in my screen nice and good for before and after results.
To be honest, I'm quite excited to see where the problem is coming from.
Post by Chief Blur Buster » 14 Sep 2017, 10:02
That's definitely image retention. (Also called "burn in", but it is typically not permanent).
What is the firmware version for this VG248QE? I'm curious if it's a specific firmware.
Also, what do you see when you view www.testufo.com/inversion ?
caseyohrn
Post by caseyohrn » 14 Sep 2017, 18:48
These are the numbers I see in service mode:
ASUS VG248QE AUOM240HW01V8
QISDA MCM101
SVN 001
This is what I see when I went to the link you posted:
https://i.imgur.com/cHOL1t5.jpg
So before I pull everything apart when the replacements come. Which part should I check first? Power supply, or motherboard? I feel I should replace the power supply first just in case the one I have currently doesn't ruin the replacement motherboard.
I should also note that I've had this monitor since August 2014. Was on vacation for over a week in July this year. When I got back home is when I started to notice this problem.
Also sold my 295x2 about a month ago. There was another issue where sometimes the screen would flicker for a split second. Thought it was an issue with my GPU. I ended up getting a 1080ti and it still flickers the same way but this is a very random occurrence that happens since I've had this monitor. Sometimes when I boot my desktop another problem is that it will only detect 60hz and not 144hz. The 295x2 used a mini DisplayPort cable that was certified. The new DisplayPort I bought for my 1080ti was purchased from Monoprice.
There's so many variables with my system, but obviously even after I install the replacement parts I'll have to keep you updated on this.
caseyohrn
Post by caseyohrn » 22 Sep 2017, 02:20
Tested and replaced both parts separately. Retention still remains.
Guessing the panel has gone bad and will just have to buy a new monitor down the road. :cry:
Post by Chief Blur Buster » 22 Sep 2017, 21:31
Damn!
Thanks for letting me know -- it is useful to know (for future reference) that this sort of problem can be also caused by the panel.
I hope you can eBay the spare parts as fully working replacement parts!
