I recently picked up a Panasonic Plasma VT60 which was one of the last great plasma displays released by Panasonic (the only better Panasonic plasma is the ZT60) and I was really impressed with it's motion clarity. Plasma displays refresh their screen differently than LCDs and OLEDs by sending pulses to the pixels every 1/10th of a second which in terms of 60Hz content means each frame is 10 pulses. This is where the "600Hz" refresh rate rating comes from and what is referred to as a sub-field drive.
This method of refreshing the screen yields better motion clarity than a typical LCD or OLED. The VT60 is rated as having a 3000Hz sub-field drive and I can see the improvements in motion clarity over other plasmas I've had. Sure, the motion clarity of a plasma isn't quite as good as a CRT or LCD with strobing but it's still satisfactory and it's cool that the motion clarity is inherent to the technology.
I understand that plasma displays aren't ideal as PC gaming monitors due to the risk of burn-in and higher input lag but from a motion clarity standpoint they are interesting displays.
Re: Panasonic Plasma VT60
600Hz sub-field drive is good but the disadvantages of sub-field drive are:
- 600Hz (for PAL on Europe) doesn't work at 60Hz while 720Hz (for NTSC America, Japan...) not work at 50Hz
- micro-stutters and/or artifacts for irregular - examples - horizontal/vertical lines, cross nets
But plasma isn't similar to CRT because the plasma gets SOFT flicker while CRT is much hard flicker and it's little harder than LED backlight.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 19" Samtron 96BDF
HDD: SATA 1TB
SED and FED screens technologies are also very interesting, flat and slim CRT, unfortunately never touch the market, only prototipes
I have the impression, that if whit modern manufacturing tecniques, one big gaming monitor manufacturer rebird today one of this beast, many were going to stay with their mouths open compared to current LED tech.
Sony show FED screen with 240Hz in older CES, is like CRT, impulsed display with 4,16ms refresh , not need strobe that adds input lag, is native impulse display, i think this beast could only be beated by future MicroLED. One shame that Sony ended up FED development
Gran Turismo 5 car game with 240FPS/Hz monitor at year 2008 !!
http://www.engadget.com/2008/11/20/sony ... t-240-fps/
More impressive than monitor is the man jacket
- GameLifter
With the sub-field drive you can also get the double image effect with 30fps content.nuninho1980 wrote: ↑24 Feb 2020, 19:22600Hz sub-field drive is good but the disadvantages of sub-field drive are:
- GameLifter
I remember when SED and FED screens were announced and later cancelled. They had potential so it was a shame they were never released.AddictFPS wrote: ↑24 Feb 2020, 23:53SED and FED screens technologies are also very interesting, flat and slim CRT, unfortunately never touch the market, only prototipes
I've got myself an P42ST30 and the motion clarity is decent but the input lag kinda kills it. At the time it was basically the best at only 16ms lag (1 frame @60hz) but in todays age it doesn't really keep up. Using a mouse on it is very laggy so it can only be used on consoles. Even though I had this TV i still chose to just hook up the hdmi to my VG236he monitor.GameLifter wrote: ↑24 Feb 2020, 13:51I recently picked up a Panasonic Plasma VT60 which was one of the last great plasma displays released by Panasonic (the only better Panasonic plasma is the ZT60) and I was really impressed with it's motion clarity. Plasma displays refresh their screen differently than LCDs and OLEDs by sending pulses to the pixels every 1/10th of a second which in terms of 60Hz content means each frame is 10 pulses. This is where the "600Hz" refresh rate rating comes from and what is referred to as a sub-field drive.
The real issue with plasma 'refresh rates' is that they don't follow the same scale of input lag. So you see giant numbers and motion is okay but it still feels like crap to play. This is opposed to the difference of 60hz and 144hz+ panels where there is a linear scale of reduction in input lag as you go up. This is not the same case in the plasma world, unfortunately. Since you need both motion clarity and low input lag levels to have an overall good experience it kinda stops this in it's tracks.
It's nice to talk about these again though, I really miss good plasmas and I feel like they could have been explored further...but one day they just gave up or something. I had no idea and sold my P65VT50 I had in storage and figured I would just buy the new model when I moved. Well, new ones never came out lol .
- GameLifter
Panasonic's last plasma models were released in 2013 and from what I've gathered they were released in limited quantities. I missed out on the really good ones when they were new but found this used VT60 for a good price locally. I have my older generation consoles like the 360 and PS3 hooked up to it and they look excellent. Plasma's definitely have a unique look to them.Dmoney405 wrote: ↑14 Mar 2020, 18:20I've got myself an P42ST30 and the motion clarity is decent but the input lag kinda kills it. At the time it was basically the best at only 16ms lag (1 frame @60hz) but in todays age it doesn't really keep up. Using a mouse on it is very laggy so it can only be used on consoles. Even though I had this TV i still chose to just hook up the hdmi to my VG236he monitor.GameLifter wrote: ↑24 Feb 2020, 13:51I recently picked up a Panasonic Plasma VT60 which was one of the last great plasma displays released by Panasonic (the only better Panasonic plasma is the ZT60) and I was really impressed with it's motion clarity. Plasma displays refresh their screen differently than LCDs and OLEDs by sending pulses to the pixels every 1/10th of a second which in terms of 60Hz content means each frame is 10 pulses. This is where the "600Hz" refresh rate rating comes from and what is referred to as a sub-field drive.
I still use my 50" ST30, I'm always annoyed by the double-image blur, BUT it's actualler better than my OLED C7 which has even worse blur.
Only C8/C9 or the incoming CX has finally good blur thanks to the optional BFI mode
I use Rayman Legends music levels to test the motion blur of a TV (there's a demo available for free on every consoles)
- GameLifter
I'm very much looking forward to the OLED CX. Some people have started getting theirs.dhaine wrote: ↑19 Mar 2020, 20:56I still use my 50" ST30, I'm always annoyed by the double-image blur, BUT it's actualler better than my OLED C7 which has even worse blur.
