Hello men,
I have my new monitor (XL2411T) since today.
I have made some tweak for the color (brightness / contrast / gamme 5 / user profile etc...)
I tried the strobelight-beta4 ----> works perfectly but .... the colors are just sooo bad.
Can someone know some good setting?
I need help with the strobelight setting ( contrast / lightboost percentage etc...) and maybe a setting for Catalyst with the color.
Thx
BenQ XL2411T and Amd r9 series
Re: BenQ XL2411T and Amd r9 series
Nobody have an amd card and use strobelight?
Yes, AMD R9 cards work with ToastyX Strobelight, according to the thread on http://www.monitortests.comcon_dition wrote:Nobody have an amd card and use strobelight?
However, if you want better colors with strobing, you will want something better than LightBoost. For better colors during blur reduction, you want to use BENQ Blur Reduction, Turbo240 or ULMB instead, all of which are better than LightBoost. For more information, see Official 120Hz Monitor List.
If better colors during blur reduction is your goal, is there any specific reason why you decided to buy the XL2411T instead of the XL2411Z (Version 2), which has BENQ Blur Reduction?
