Hey, first time round here so please go easy on me if i say or do something wrong
So i own the Msi mag274qrf-qd, i mainly used it for more story orientated/chilled back games. I recently got back into more competitive games and ive tried the anti motion blur setting which the the BFI setting on the monitor and ive noticed it looks and feels signifcantly smoother. However the brightness took a hit, which is what brought me here. I am not very well versed in the monitor department so I when it comes to monitor settings its all foreign to me for the most part, best i can do is adjust the brightness knowing what that does.
So i was wondering if anyone here can help me out with any settings they'd recommend or try and mess with to help with the image after turing BFI on. I fully understand i wont be able to get the brightness and vibrancy back but id like to try get some more life out of the image as it kinda looks dark and greyed out-ish.
Thanks.
Best settings for MSI mag274qrf-qd when using BFI?
Re: Best settings for MSI mag274qrf-qd when using BFI?
No but yes the motion blur reduction is HUGE but this requires the hardware or software strobe support for the thin monitor. But the disadvantage of software strobe is little randomly stuttering by frame and/or by flicker.
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 19" Samtron 96BDF
HDD: SATA 1TB
