Acer GN 246 Lightboost hack support?
Motion blur eliminating strobe backlights found in gaming monitors. This includes NVIDIA LightBoost, Ultra Low Motion Blur (ULMB), EIZO Turbo240, ToastyX Strobelight utility, etc.
Re: Acer GN 246 Lightboost hack support?
Postby ImJLu » 29 Jun 2015, 19:46
I'm not sure what you mean by "locked out of the OSD." The only thing I can think of is this: http://i.imgur.com/eCrroMx.png which I'm definitely not locked out of. What are you referring to?
ImJLu
Postby Falkentyne » 29 Jun 2015, 22:14
I mean, locked out of the color, brightness and gamma settings, overdrive, sharpness, etc.
Falkentyne
Postby chronosXIII » 30 Dec 2016, 23:42
Sorry for reviving this thread - but I found it is the most informative one on this monitor! I am also locked out of this setting, is there anything I can do to get into it? I am trying to get lightboost to work
https://i.imgur.com/lJWsgxP.jpg
chronosXIII
Postby Chief Blur Buster » 03 Jan 2017, 02:35
Strobelight won't work.
You will need to use another LightBoost hack method at www.blurbusters.com/lightboost/howto ....
(e.g. The EDID override method, or another method)
Previous
Return to Eliminating Motion Blur (LightBoost, ULMB, etc)
Who is online
Users browsing this forum: No registered users and 1 guest
