I have found a neat soft that can change the monitor backlight.
http://screenwhite.com/screenbright/
Is it possible to using this ddc/ci method and some custom software to strobe the backlight in accordance with the display refresh rate?
For example:
I watch 24fps movies on my 72Hz monitor.
I want the back light to flash 3 time each movie frame (just like cinema), so a 72hz strobing would be ideal.
1/72 = 13.88ms, so even a slow strobing (>2ms) will be fine.
Can a software+DDC/CI do that?
My current monitor is not LightBoost capable, but its a w-led & ddc/ci.
EDIT:
Nevermind, just realized that the brightness control controls the pwm of the voltage and in no way we can fully turn it off.
DDC/CI Software Backlight Strobing?
- James Freeman
Re: DDC/CI Software Backlight Strobing?
you are a goddamn genius!
No, DDC is too slow to do that.
I agree.ToastyX wrote:No, DDC is too slow to do that.
Plus:
(1) You need high precision (<1ms, preferably <0.2ms) for timing the strobes, relative to VSYNC.
(2) You need ultrahigh precision (<10 microsecond) for strobe length.
(3) You must repeat all the above correctly every single time (e.g. 120 times a second)
Strobe length consistency is more important than strobe timing consistency (depending on how large the blanking interval is).
It's easy to see random flicker in a poor-quality strobe backlight that varies 1%-2% in strobe length. That means 10-20 microsecond variances in a 1ms strobe backlight. Every 10 microsecond error creates a flicker of 1% brighter/dimmer, so you MUST have extremely high precision in your backlight/edgelight electronics. (10 microsecond is a full 1% of 1 millisecond, which is why you can visually see brightness differences).
DDC/CI cannot be used as a means of introducing motion blur reduction backlighting, as there's several milliseconds of latency, and too much jitter on a serial (I2C) bus.
Also, I created this page: Electronics Hacking: Creating a Strobe Backlight. Blur Busters started in 2012 originally as http://www.scanningbacklight.com when I experimented with an Arduino scanning backlight, before the discovery of LightBoost.
Also, you would need hard real-time requirements on the OS side to do it with software. Neither Windows, nor Mac nor Linux can do that.
Chief, is there an opportunity for variable strobe length and timing, as long as more important factors such as average light output are maintained? This is obviously relevant for variable frame rates but also for potential subframe rendering techniques such as smooth frame insertion, to increase light output, and avoiding flicker and double-imaging for low frame rate sources.Chief Blur Buster wrote:
