1) How can i know if my Vertical Total is set to 1350? I'm using CRU by ToastyX since i have an AMD GPU.
I did everything. I created a detailed resolution 1920x1080 @ 120hz, 1350VT and i'm not sure how do i activate it. Is it the native resolution of the monitor ?
2) Oh and another question: If i'm playing cs:go at a 1280x960 4:3 stretched resolution will the 1350VT tweak work?
3) What about persistance to 0ms and crosstalk down to the left?
UP
Vertical Total 1350
- masterotaku
Re: Vertical Total 1350
First of all: what is your monitor? You're posting in the Lightboost & ULMB section. Vertical Total is irrelevant for those two technologies.Foxeran wrote:1) How can i know if my Vertical Total is set to 1350? I'm using CRU by ToastyX since i have an AMD GPU.
In case you have a BenQ Z series, check the "Current Resolution" in the monitor OSD. System -> Information -> Current Resolution.
If it says it's running at 60Hz while you're actually using 120Hz, then it's working.
It should work with GPU scaling.Foxeran wrote:2) Oh and another question: If i'm playing cs:go at a 1280x960 4:3 stretched resolution will the 1350VT tweak work?
0ms is just the monitor turned off . Just kidding, I know you meant some other number.Foxeran wrote:3) What about persistance to 0ms and crosstalk down to the left?
The persistence setting depends on the refresh rate. The higher the refresh rate, the lower the persistence is at the same setting. I guess they made that to compensate the higher Hz, because a higher number of strobes per second increases brightness.
If you're using a custom resolution, that makes the monitor use the 60Hz strobe lengths, and that's why the monitor OSD says it's running at 60Hz and why people say it's brighter (it's brighter because it's just using a higher persistence).
In the blurbusters strobe utility, the numbers in miliseconds correspond with the 60Hz strobe lengths.
The crosstalk zone depends on the Vertical Total. Try it yourself to see what suits you better.
Monitor: Asus PG278QR
