Disabling blurbusters does nothing but controls work?
Is this correct? If I uncheck the box to enable it, nothing changes. But all the sliders work and change the brightness. It also detects a supported monitor. Also, noob question, but do you have to run the Lightboost app for it to work? It's like its always enabled on mine without running the program even on a fresh boot.
- lexlazootin
Re: Disabling blurbusters does nothing but controls work?
Turn off 'Blur Reduction' on your monitor to disable 'lightboost'. Lightboost will work even without the program, it's just more custom options if you have it.
