Hello,
i just got the AOC G2460P:
http://us.aoc.com/monitor_displays/g2460pqu
i can lightboost him?
or there is way to confing him..
i play most the cs go..
Thanks for help
Settings for AOC G2460P Monitor.
Re: Settings for AOC G2460P Monitor.
That monitor does not accept 3d vision 2.
https://pcmonitors.info/reviews/aoc-g2460pqu/
Lightboost will not work at all.
Not only that, the overdrive mechanism is disabled at 120 and 144hz completely, meaning the monitor operates at the equivalent of overdrive off or weak (at 60hz). Not the best monitor to buy.
It uses the same panel as Asus VG248QE and Benq XL2411T/Z.
No idea what scaler or firmware flash chip it uses.
