Asus PG279Q Issue with ULMB - Backlight turning off?
shockwave818
Post by shockwave818 » 09 Feb 2016, 14:57
Wondering if the issue I'm seeing with my PG279Q is being seen by others...
I'm seeing a big issue with enabling ULMB with the monitor.
- I set the refresh rate of the monitor to 120hz via the windows display panel - everything works fine.
- I then enter the monitor's menu using the joystick/buttons - everything is still fine.
- I select and enable ULMB - everything is still fine.
- I then exit the on-screen menu - EVERYTHING IS NOT FINE. The screen goes black, and I can see the desktop VERY faintly (I think the backlight may be turned off)
- I then turn the monitor off via the power button and let it sit for 5 seconds
- I then turn the monitor back on via the power button and my desktop will come back - ULMB is also now enabled
- If I do anything with the on screen menu, it does the same thing when exiting the menu - screen goes black. And I have to power cycle the monitor to get anything back.
I am running a 970GTX and the latest drivers. Monitor is connected via the DP cord that came with it.
psY
Re: Asus PG279Q Issue with ULMB - Backlight turning off?
Post by psY » 22 Feb 2016, 18:10
Same problem here ...
shockwave818
Post by shockwave818 » 08 Jun 2016, 14:04
Hi Psy,
Still having the same issue? I haven't found a fix yet.
