ULMB and Overwatch
ULMB and Overwatch
Cant seem to find the answer in the FAQS, so im asking here: im running ULMB on a 120hz configuration playing Overwatch. Overwatch has this awkward fps cap settings where you basically set your refresh rate and then it gets capped at that +10. so theres either 144hz (154fps cap) or 120hz (130 fps cap) and 100 hz (110fps cap). what would be the best with ULMB? thanks in advance
Re: ULMB and Overwatch
Can't you edit the ini file to set a different cap?
You can but it rounds up to default settings even write protectedSparky wrote:Can't you edit the ini file to set a different cap?
I think putting it to 120hz ulmb and enabling fast sync would give you the best experience in most cases. You do have to make sure you can keep up the frame rate though. I wouldn't bother with separate fps caps below refresh rates or something since that will only mess up the timings more.
