Lightboost on ASUS VG248QE with G-sync module
Can I turn on lightboost 10% on ASUS VG248QE which has G-sync module with ULMB ? Or only ULMB ?
- lexlazootin
Re: Lightboost on ASUS VG248QE with G-sync module
I'm a little confused what you mean, in my benq G-Sync i can customize the Pulse Width to my liking 100-0 but you can't enable both G-Sync and ULMB at the same time if that's what you're talking about.
If you are talking about just doing ULMB through the G-Sync port, that is possible.
