strobelight brightness to high at 10%? vg248qe
Motion blur eliminating strobe backlights found in gaming monitors. This includes NVIDIA LightBoost, Ultra Low Motion Blur (ULMB), EIZO Turbo240, ToastyX Strobelight utility, etc.
Postby 73nismit » 03 Jan 2017, 12:30
Hi all,
I"m using the asus vg248qe with strobelight (amd gpu). I always use 10% which is the lowest setting, but I still find it to bright. Is there a way to decrease the brightness while strobing? The monitor always runs on 0% brightness in the osd. When strobelight is enabled the monitor becomes brighter. Is there a way to use 2% brightness for example to reduce the brightness en may increase the benefits from strobing?
73nismit.
73nismit
Return to Eliminating Motion Blur (LightBoost, ULMB, etc)
Who is online
Users browsing this forum: Google [Bot] and 4 guests
