Asus ROG Swift PG258Q
Tried everything!
I've had multiple G-sync/Ulmb monitors so I know how to set it up.
I'm starting to think monitor is defective.
Thanks in advance!
ULMB greyed out in OSD menu
Re: ULMB greyed out in OSD menu
Well, since you said you know how to set it up, I'm not gonna post troubleshooting advice. So just send it back then.
I must be missing something...
Well, the only two things required are: 1) g-sync must be disabled in the nvidia control panel, and 2) you need to be currently running a refresh rate for which ULMB is supported.
So check your monitor's OSD. In the information section, is the current mode "G-SYNC" or "Normal" (or "Fixed")? What is the current refresh rate? Is that refresh rate supported by ULMB?
Yes 1 an 2 are mandatory, I tried 60-119-120 etc, custom resolution with different hz. Even the OSD hz says it changed and it's displayed accordingly, but ULMB section still greyed.
I turned it on and off, disconnected DP cable and reconnect.
I messed up in NVidia CPanel, gsync, ulmb, fixed RR.
- Full hard power reset (unplug-replug) of monitor
- Full uninstall-reinstall of graphics drivers
- Try a different port on your graphics card
All this did not work.
But.
Inadvertently, while searching in OSD menu for several minutes, display went to sleep because i wasn't using mouse.
So I move the mouse and what do you know, while still in OSD menu, ULMB went available...
But it wont stay if I do anything, change hz, monitor off/on, launch a game... what the heck.
So right now only possible way to get ULMB available is to wait for monitor to go to sleep and light it up again, but can't use it.
Monitor led is yellow when ULMB and goes red for G-Sync. It always go back immediately to G-Sync if any action is made.
But.
- Make sure you have the correct refresh rate (120.0000000Hz)
- You can try Start->Power->Sleep to force-sleep your monitor, and then wake your monitor again.
Or RMA it.
For anyone who is looking to enable ULMB2 (and probably good general advice for this feature):
Make sure Power Save isn't turned on on your monitor.
https://ibb.co/v3J56S0
