Acer XB270HA 27" 1080p 144hz
Joolsyz
Re: Acer XB270HA 27" 1080p 144hz
Post by Joolsyz » 17 Jan 2015, 13:32
Overall picture and colors seems much better out of the box than my older monitor the BenQ XL2410T which I could only get looking good with an ICC profile.
OutlawXGP
Post by OutlawXGP » 18 Jan 2015, 05:25
Scan just got the AOC G2460PG in stock, but would you recommend it over the Acer XB270HA 27"? They are both around the same price range but i am not sure which one will have the better picture quality and black levels.
silverfoxxxx
Post by silverfoxxxx » 18 Jan 2015, 05:48
I guess you would have to weigh up the 1080p at 24" and 27" as other than that they both should deliver great results, I'm very happy with mine and love the screen size, have you got a shop nearby where you could view some different screen sizes? It would also depend on your sitting distance from the screen.
You can also negate some of the issue by using nvidia dsr, which I do use in some games and it works well, not great for fast paced games but elite dangerous for instance looks much better scaled in a higher res.
OutlawXGP
Post by OutlawXGP » 18 Jan 2015, 08:58
To be honest with you I don't think I would mind the fact that the difference is 1080p 27 inch or 1080p 24 inch, what I do really care about is colour quality and black levels, I am aware that u can't get amazing black levels on today's monitor technology unless its VA however I really hate to buy a screen that has "Gray layer of washed out effect" over the colours or extremely bright blacks, because that would make playing games like Outlast or Skyrim a poor experience.
This is what I am truly afraid of so I like to know which of these 2 produce the better picture quality overall.
Valery67
Post by Valery67 » 07 Feb 2015, 10:21
Hello, it is going to make 1 month that I have this monitor and unfortunately yesterday I changed colors "warm" and "cool" and I do not know any more which are the values by default. Factory reset does not work for these values.
To change the values, it is necessary to maintain the button quite to the left + the button power. Later it is necessary to go to the menu acer and to click the icon F which appeared..
Can you give me the values for 6300K and 9500K?
Thank you
Mareczq
Post by Mareczq » 20 Feb 2015, 16:52
Sow any one have some new great settings I Can try?
This is my first monitor in a long!!! time ;) I am new in this stuff, but i still thinkt its not set propley ;)
I used Prad.De settings:
Brightness
35
Contrast
50
RGB Gain
44 50 46
Gradation
Gamma 1.9
And i am not sure its good, i liked colors more with my previous monitor (i got some old viewsonic VA monitor).
mminedune
Post by mminedune » 25 Feb 2015, 15:42
Any idea if the XB240H *UM.FB0AA.A01* has 8bit panel ?
Mdubz
Post by Mdubz » 27 Feb 2015, 23:59
Is the XB240H currently the cheapest G-Sync monitor available in the US?
mminedune
Post by mminedune » 28 Feb 2015, 09:37
No AOC G2460PG is same price.
Ive been waiting forever for glossy panel but still nothing so if this 24 model has 8bit i might ge.
They have at microcenter so i might just pick one up locally when i get me tax returns and check it out IDK
Mdubz
Post by Mdubz » 28 Feb 2015, 14:34
mminedune wrote:No AOC G2460PG is same price.
Can't find the AOC G2460PG anywhere except Microcenter, and even there it is $449 with in-store pickup only. The Acer XB240H is only $399.99 + $10.53 shipping from Amazon, which I believe makes it the current lowest price G-Sync monitor.
