Greetings
I've had to create an account because I can't find any solution and I don't know who to ask for help.
When I use Gsync with the borderless window option enabled and play certain games in borderless window, if I alt+tab and go to any window, it stutters for a second or two.
The strange thing is that it didn't happen with my previous monitor: MSI Optix MAG274QRF but it happens with the current one: AORUS FI27Q-P.
I tried using DDU and reinstalling drivers but it didn't help.
I know it's the Gsync because when I disable the borderless window option and it doesn't appear as active in the game, this problem disappears.
What can I do to solve this?
Thank you very much for your time
Pd: I'm sorry if this is not the correct place to post my problem.
Gsync & borderless screen - stutter when alt+tab
Re: Gsync & borderless screen - stutter when alt+tab
Displays: ASUS PG27AQN, LG 48C4 VR: Beyond, Quest 3, Reverb G2, Index OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboards: Wooting 60HE, Logitech G915 TKL Mice: Razer Viper Mini SE, Razer Viper 8kHz Sound: Creative Sound Blaster Katana V2 (speakers/amp/DAC), AFUL Performer 8 (IEMs)
Hi, first of all thanks for your reply.jorimt wrote: ↑12 Feb 2023, 13:41Start by first ruling out MPO:
viewtopic.php?f=5&t=10730&p=87330&hilit=mpo#p87330
I have tried the solution you mentioned but unfortunately no luck.
What else can I do?
Thank you for your time.
If it's not MPO, it may be a difference in the factory EDID and/or firmware behavior on your current monitor model vs your old one. I remember similar alt + tab issues being reported for other FreeSync models in the past.jakfear863 wrote: ↑13 Feb 2023, 06:55I have tried the solution you mentioned but unfortunately no luck.
What else can I do?
What OS are you running? If it's Windows 11, there's an option in newer versions that you could try disabling. If you have Win 11, let me know, and I'll give you the location.
Other than that, the only other thing I can think off-the-top-of-my-head is to enable G-SYNC for fullscreen mode only in the NVCP, and then apply borderless/windowed G-SYNC mode selectively via Nvidia Inspector (if you're not doing it already).
Instructions for that are in entry #5 of my Closing FAQ here:
https://blurbusters.com/gsync/gsync101- ... ttings/15/
Hijorimt wrote: ↑14 Feb 2023, 17:11If it's not MPO, it may be a difference in the factory EDID and/or firmware behavior on your current monitor model vs your old one. I remember similar alt + tab issues being reported for other FreeSync models in the past.jakfear863 wrote: ↑13 Feb 2023, 06:55I have tried the solution you mentioned but unfortunately no luck.
What else can I do?
I am using windows 10 in almost its latest version
I'm going to try the nvidiaPorileInspector solution and see how it works.
Thanks for your time
Hi, sorry for the delayjorimt wrote: ↑14 Feb 2023, 17:11If it's not MPO, it may be a difference in the factory EDID and/or firmware behavior on your current monitor model vs your old one. I remember similar alt + tab issues being reported for other FreeSync models in the past.jakfear863 wrote: ↑13 Feb 2023, 06:55I have tried the solution you mentioned but unfortunately no luck.
What else can I do?
The entry 5 fixed my problem so thanks you.
Good to hear
