A while back, some people claimed 3D Vision is built-in into the G-Sync module and thus works on all G-Sync monitors that can do 120Hz and ULMB:
http://www.mtbs3d.com/index.php?option= ... &Itemid=73
Nobody seems to have tried that yet though. And no official confirmation ever came from NVidia.
Unfortunately, I don't have a 3D Vision kit. If anyone here has a full kit (USB IR emitter + glasses), *and* a G-Sync monitor that does not have the "3D Vision" logo/certification on it and is not sold/advertised as "3D Vision Ready" or anything like that, but does have ULMB and at least 120Hz, this would be a nice test.
Or if someone has actual contacts at NVidia, they could ask too, I guess
Apparently 3D Vision should work on ALL G-Sync monitors?
Re: Apparently 3D Vision should work on ALL G-Sync monitors?
As far as I know, it should be in all 144Hz+ TN G-SYNC monitors, yes.RealNC wrote:A while back, some people claimed 3D Vision is built-in into the G-Sync module and thus works on all G-Sync monitors that can do 120Hz and ULMB:
I believe, and from all anecdotes I've read 3D Vision had always worked on the TN ones. Generally, it has been package deal for 144Hz+ TN panels, G-SYNC + ULMB + 3DVision is part of NVIDIA programming in TN G-SYNC firmwares. But not on all G-SYNC monitors in general.
There are 100Hz and 120Hz G-SYNC monitors that does not even manage to have strobing, due to panel limitations (e.g. VA, IPS).
See List of G-SYNC Monitors for G-SYNC monitors with ULMB, versus without ULMB. Generally, if it's TN and if it has ULMB, then it also has hidden 3D Vision support too.
There are 3D Vision compatible displays not even listed on NVIDIA's official list of 3D Vision Ready displays. This may be because that particular display may not have the LightBoost backlight overvoltage technique of brighter strobe flashes. If it doesn't have that, it's not allowed to be officially advertised as LightBoost or 3DVision. But generally, ULMB and LightBoost is otherwise very nearly identical but not the same overdrive/picture settings (LIghtBoost uses a slightly different overdrive algorithm -- LightBoost has lower contrast / lower dynamic range in order to improve overdrive to reduce strobe crosstalk). So it may be an unadvertised feature.
Also, it's possible to co-opt ULMB (combined with an emitter emulator) to be the 3D Vision strobe backlight. So even if LightBoost (Might be worth a try in the IPS / VA ones... I haven't heard of anyone successfully doing 3D Vision on those)
So since I'm on IPS (even though it does ULMB strobing and supports 120Hz), it will probably not work simply because it's IPS?
I really wish there was some official statement from NVidia on this though. Unfortunately, I don't live in a region where I can buy a 3D Vision kit and then send it back simply because "I don't like it." It has to be defective, otherwise you can't send it back
Edit:
No, wait, you said 144Hz, not 120Hz. I thought 3D Vision was 120Hz strobed (60Hz for each eye.)
Edit:
Yes, 120Hz strobed.RealNC wrote:No, wait, you said 144Hz, not 120Hz. I thought 3D Vision was 120Hz strobed (60Hz for each eye.)
There's very few TN monitors that can't do 144Hz. Indeed, early 120Hz monitors (e.g. VG278H before the VG278HE) omitted the 144Hz feature, even though they had 120Hz nonstrobed and strobed. But today, no currently-manufactured TN monitors capable of 3D Vision does less than 144Hz non-strobed.
Generally, a monitor kinda needs to be capable of "144Hz non-strobed" in order to be able to do "120Hz strobed" without too much crosstalk.
The one I got here does 165Hz even though it's IPS, so it should theoretically qualifyChief Blur Buster wrote:Generally, a monitor kinda needs to be capable of "144Hz non-strobed" in order to be able to do "120Hz strobed" without too much crosstalk.
The thing is that nobody ever tested. Hence my request to people with non-3D monitors to test them if they have a kit I understand why NVidia doesn't want to say anything about this, since people might get disappointed by crosstalk or brightness issues. But building an unofficial list of monitors that work with a 3D kit would be useful.
- lexlazootin
Just change the monitor id to ACI27F8 in CRU, that will let you pass the prerequisites and enable 3D.
Alright, I found what appears to be the first report of a non-certified monitor working with 3D vision:
https://forums.geforce.com/default/topi ... 271hu-yes-
It's the Acer XB271HU, an IPS monitor that is very similar to my XG2703-GS (spec-wise, it looks like it's 1:1 identical.)
I've got the Acer XB270HU, I wonder if it'll work. Then again, I usually game on my projector, and...I avoided purchasing Nvidia 3D stuff due to poor support.
TBH 3D support via either LCD or LCoS is almost always inferior to DLP and I'd rather 60hz per eye via SBS on my DLP (0 pixel transition time between frames, no crosstalk whatsoever due to the digital nature of DLP). Even more importantly, if you want 3D for gaming, you're better off with a VR helmet (maybe wait for 2nd gen, wireless versions).
