Post by RealNC » 14 Nov 2023, 08:13
rasdore wrote:
13 Nov 2023, 22:53
Good afternoon, thank you for the guide. I play Hunt Showdown on PC and my framerate is not stable even on minimum settings (120-160 fps), as is the frame. Monitor - Asus PG258Q (g-sync, overdrive, 240hz), video card - nvidia suprimx 3080. After reading the manual, I could not find the settings for myself. I ask for your help, I will be glad for any hint. In search of the lowest latency with an adequate frame rate...
If 120 is the lowest FPS, then cap to 120 and see if you like the result.
Post by jorimt » 14 Nov 2023, 09:01
rasdore wrote:
13 Nov 2023, 22:53
I answered your question in my article comments, but as I said there, G-SYNC will not strictly improve performance, only prevent tearing.
What average framerate your system can achieve in that particular game is unrelated to optimal G-SYNC settings and down the capability of your specs, so you'll need to determine your lowest achievable average framerate and then limit it slightly below that target for a more consistent experience.
rasdore
Post by rasdore » 14 Nov 2023, 09:34
https://imgur.com/a/0N47wCO
These are my performance with v sync + g sync + low latency + frame limit by nvidia. Is it possible to somehow change the delay? I see gaps in the image when the framerate drops to 100-120. 140-180 is normal.
rasdore
Post by rasdore » 14 Nov 2023, 09:39
RealNC wrote:
14 Nov 2023, 08:13
rasdore wrote:
13 Nov 2023, 22:53
At 240 Hz, 120 frames in this game look very sluggish and out of sync with sudden movements. If I don’t lower the monitor’s Hertz, is there no way out?
Post by jorimt » 14 Nov 2023, 09:39
rasdore wrote:
14 Nov 2023, 09:34
This is not related to G-SYNC settings. Please create a new topic here:
viewforum.php?f=2
toprak
Post by toprak » 02 Mar 2024, 11:17
I do not know its nature, but I am trying to use it on mpv, it seems it works but should not it have fixed fps? I mean video is 23.97 fps but my hertz is not stable its moves around 48-165 does it work in that way? I have Lenovo R25i-30 adn RTX 3050
Mwandishi
Post by Mwandishi » 09 Apr 2024, 08:45
I hope somebody could help me with that?
What is the benefit of having v-sync 'on' within the g-sync range: variable refresh rate? I have not noticed any difference in quake champions.
Post by RealNC » 09 Apr 2024, 16:09
Mwandishi wrote:
09 Apr 2024, 08:45
It prevents tearing in cases where you get tearing. If you don't have any cases where you get tearing, then it won't do anything. Tearing with g-sync can happen sometimes at the very bottom of the screen.
