Overclocking monitor side effects?
Advanced display talk, display hackers, advanced game programmers, scientists, display researchers, display manufacturers, vision researchers. The masters on Blur Busters.
Postby flagbender » 28 Feb 2016, 21:12
I've slightly overclocked my monitor using ToastyX's CRU. The frame skipping check showed up fine on my phone's camera, but I wonder if that's the end of the story.
Could there be additional input lag? Could there be hitches or stutter of some kind? Could it change backlight behaviour possibly? Does it matter that I have RTC/overdrive enabled on my monitor?
flagbender
Re: Overclocking monitor side effects?
Postby Q83Ia7ta » 29 Feb 2016, 04:18
flagbender wrote:I've slightly overclocked my monitor using ToastyX's CRU. The frame skipping check showed up fine on my phone's camera, but I wonder if that's the end of the story.
Overclocked mine X-Star DP2414LED from default 144Hz to 201-202 at September 2015 and have no any problems. I've never seen negative experience of tv/monitor overclocking at forums.
But monitors firmware is black box.
May be some monitors add input lag or do something worse at unsupported modes. But I'm sure this cases are very very low.
To compare results of input lag, overdrive quality, response time and etc between overclocked and non-overclocked state requires some skills and equipment so there are not so many results.
Q83Ia7ta
Postby flagbender » 29 Feb 2016, 04:43
Fair enough, no way to know, eh? I don't have the equipment so I'll just stick with the defaults.
Thanks for the input
flagbender
Return to Area 51: Display Science, Research & Engineering
Who is online
Users browsing this forum: No registered users and 1 guest
