Unfortuantely it doesn't work that way. Effective GtG would closer to slowest of the two.blurfreeCRTGimp wrote: ↑17 Jan 2021, 16:23If you used an OLED as a backlight that was monochrome, but then used an LCD for a color shutter couldn't you get much better response times for GTG and color transitions? Since OLED has like .2ms transition time from White to black, if you used an LCD as a color shutter like an old LCCS CRT?
LPD: Laser Phosphor Display - Successor to CRT?
Re: LPD: Laser Phosphor Display - Successor to CRT?
