HOWTO: Quick Frame Transport (QFT) - Large Vertical Totals (reduce lag, reduce crosstalk)
Posted: 08 Aug 2021, 04:15
What are Large Vertical Totals / Quick Frame Transport?
It's a method of reducing latency of video signals & improving the quality of strobe backlight modes (less strobe crosstalk). For more information about tuning a monitor via Strobe Utility, see www.blurbusters.com/xg2431
Large Vertical Totals are also known as Quick Frame Transport aka QFT, because they speed up the delivery of the refresh cycle over the cable, e.g. a 120Hz refresh cycle in 1/240sec on a 240Hz monitor. There are two big reasons:
1. Reduce Input Lag
2. Reduce Strobe Crosstalk
Usually QFT is only useful for lower refresh rates on a higher Hz panel.
More Reading
There's additional bigger articles about Large Vertical Totals (QFT)
1. Custom Resolution Utility Glossary
2. Quick Frame Transport (Large Vertical Totals)
3. HOWTO: Settings For Full Panel Crosstalk-Free Low-Lag Strobing (ViewSonic XG2431)
4. Why Is Refresh Rate Headroom Good For Strobe Backlight Motion Blur Reduction?
5. Different 240 Hz Panels That Are Laggy For 60 Hz, While Others Are Not
Quick Frame Transport works on all video cables including HDMI, DisplayPort and Thunderbolt/USB-C (DisplayPort mode).
How does Quick Frame Transport Work?
Until manufacturers natively implement QFT into monitor firmware, it has to be created manually on a PC. You need a Custom Resolution Utility to create QFT modes, such as ToastyX CRU from www.monitortests.com ... You will see complicated numbers in a Custom Resolution Utility. To understand better, it is simply modifications to signal geometry including hidden pixels off the edges of the screen:
Pixels are transmitted over a video cable one pixel row at a time, top-to-bottom. This is essentially a serialization of a 2D image (a refresh cycle) into a one-dimensional medium (a video cable), which we've been doing ever since raster video was invented more than a century ago. Pixels are transmitted like a book (left to right, top to bottom) and the pixels of a display signal are normally delivered in the same order.
The horizontal porches and sync intervals are separators between pixel rows.
The vertical porches and sync intervals are separators between refresh cycles.
To speed up frame delivery for a lower refresh rate (on a high Hz monitor), you ideally want a large blanking interval (a huge separator between refresh cycles). For a 240 Hz monitor, it means it is possible to have a 120Hz refresh cycle delivered in 1/240sec, or a 60Hz refresh cycle in 1/240sec.
Note: QFT generally doesn't help non-strobed VSYNC OFF or VRR (already defacto QFT-like behaviors). QFT helps reduce lag of synchronized technologies such as strobing or VSYNC ON. Yes, it will reduce lag of strobed VSYNC OFF or non-strobed VSYNC ON. It just doesn't always reduce lag of non-strobed VSYNC OFF (unless it's a fixed-scanrate panel). The mathematical and technical reasons will be omitted from here for simplicity's sake, but this question can be answered with a complex Area51-worthy answer upon request.
Comparison of Fixed-Hz QFT to Variable Refresh Rate
Download, install and run ToastyX from www.monitortests.com then click "Add" to begin creating a new custom resolution.
Important: Unless intentional, it is best to disable VRR (FreeSync, G-SYNC) both in your monitor's OSD and on your computer side, before beginning to do these tweaks.
The easiest steps are to use ToastyX and derive from a WORKING mode.
1. Start with working max-Hz mode
On most modern panels, the existing default max-Hz mode built into monitor's EDID will work.
2. Switch to Manual
3. Put First Radio Button on "Total"
4. Put Second Radio Button on "Horizontal" (or "Pixel Clock")
Now you can choose a custom large vertical total by increasing the Vertical Total to lower your Hz to target Hz
Your horizontal scan rate and pixel clock will stay unchanged as you transfer bandwidth from Hz to Vertical Total
You're still transmitting the same number of pixel rows per second over the cable, just fewer visible pixel rows, and more offscreen blanking interval pixel rows). The net result is that the visible pixel rows are always transmitted from GPU to monitor at full velocity at monitor's max-Hz velocity despite having a lower fixed Hz refresh rate
5. Example1: Double Vertical Total to Halve Hz (2x QFT at half Hz)
This example transmits a 8.3ms(1/120sec) refresh cycle in only 4.2ms(1/240sec) resulting in 4.2ms lag saving for bottom screen edge
This will transmit the refresh cycle over the video cable at 2x its normal low-Hz velocity
Do not edit any other numbers, do not edit Hz, only edit Vertical Total, the refresh rate will be calculated automatically
6. Example2: Quadruple Vertical Total to Quarter Hz (4x QFT at quarter Hz)
This example transmits a 16.7ms(1/60sec) refresh cycle in only 4.2ms(1/240sec) resulting in 12.9ms lag saving for bottom screen edge
This will transmit the refresh cycle over the video cable at 4x its normal low-Hz velocity
Once you create your custom mode, reboot your computer (or run ToastyX restart64.exe to reboot your GPU without needing to reboot Windows). Test your custom mode. Verify your new Vertical Total shows up in Strobe Utility too. If it works, repeat the DIY strobe tuning steps above to get your reduced strobe crosstalk & low lag.
For intermediate refresh rates, calculate the vertical total using this formula:
Desired Vertical Total = (Original Vertical Total) x (Original Hz) / (Destination Hz)
Currently, this is the easiest way to create QFT modes at this time. We are still waiting for a monitor manufacturer to pre-program plug-n-play QFT EDIDs into the monitor that can be enabled/disabled via a "Quick Frame Transport: ON/OFF" setting.
BONUS QFT can compensate for poor 60Hz latencies of 240Hz panels! Most 240Hz panels do a very bad job of 60Hz lag (see diagrams), but QFT can compensate fully for this (as long as the device supports QFT -- such as a PC). Consoles such as XBox and PlayStation are currently out of luck at this time (though hardware EDIDs need to be tested for undocumented XBoxSeries/PS5 support).
Strobe Crosstalk Reductions: Fewer Double Images During Blur Reduction
More VBI time to hide LCD GtG pixel response between refresh cycles results in a much taller zero-crosstalk zone (as an additional benefit above-and-beyond latency reductions). As long as you're doing framerate=Hz, you can get much more perfect CRT motion clarity:
Both the new 60Hz single-strobe monitors tuned by Blur Busters support QFT 60 Hz single strobe modes, include the ViewSonic XG2431 (Blur Busters Approved 2.0) and the Eve Spectrum 4K144 (Tuned by Blur Busters).
Caveats
NOTE #1: Occasionally, QFT modes may interfere with non-QFT modes, you may have to delete the original non-QFT mode from ToastyX. Alternatively, duplicate the QFT numbers you have in ToastyX into NVIDIA Control Panel (so both ToastyX and NVIDIA has it), to force-override an existing non-QFT mode (e.g. replacing existing 60Hz mode with QFT 60Hz mode).
NOTE #2: QFT mainly supports strobed VSYNC ON, strobed VSYNC OFF, or nonstrobed VSYNC ON. Fast Sync / Enhanced Sync / RTSS Scanline Sync can be used too, to reduce lag even further. QFT does not always reduce latency of non-strobed VSYNC OFF or VRR, unless it is a fixed-scanrate panel being driven at a lower signal scanrate (see diagrams).
WARNING: Custom Resolution Utility tweaking can cause your monitor to go OUT OF RANGE. Please do not do advanced steps (e.g. Custom Resolution via NVIDIA Control Panel or ToastyX) without knowing what you are doing. Make sure you know how to use such utilities before following such steps. Make sure you have a 2nd monitor, so you can more easily undo OUT-OF-RANGE modes. Another trick is to switch inputs on the ViewSonic (use HDMI instead of DisplayPort, or DisplayPort instead of HDMI) to get a picture back to allow you to undo your tweak. The popular utility, ToastyX CRU, includes reset-all.exe which you can run to undo all mis-tweaking. Safe Tweaking!
IMPORTANT: To Finish QFT strobe crosstalk reduction:
- For ViewSonic XG2431, readjust via ViewSonic Strobe Utility
- For BenQ XL2411/XL2720, readjust via BenQ Strobe Utility
- For Eve Spectrum, readjust via Eve Strobe Utility
1. Reduce Input Lag
More Reading
- FreeSync/G-SYNC are already defacto automatic QFT modes. It's easier to reduce latency via a capped FreeSync/G-SYNC mode as they are the world's lowest latency non-VSYNC-OFF technologies.
- FreeSync/G-SYNC variable refresh rate are are always permanently max-Hz and use a variable-sized vertical total (via varying the vertical porch) to dynamically vary the refresh rate. If you can use VRR instead of QFT, please do so. Capped VRR is much easier than fixed-Hz QFT.
- However, there are many reasons why you may need a fixed-Hz QFT / Large Vertical Total mode instead (e.g. certain retro content, fighting games, emulators, low-latency strobing, low-crosstalk strobing). Most strobe modes on most monitors only support fixed-Hz, or produces the best image quality during fixed-Hz.
- This specific HOWTO teaches you how to manually create a fixed-Hz QFT mode that is useful for reducing low-Hz latency on a high-Hz monitor, as well as reducing strobe crosstalk.
2. Switch to Manual
Caveats
