Hi. I've got benq xl2411z. I got a couple of question to you guys
1. I playing fps games (coutner strike global offensive) and what's the best options in benq settings to get the most advantage ? The best quality and smooth etc? How to see people "faster".
Best ama setting? Insant mode off/on? etc ? Can you help me?
2. What is better, 144hz or 120hz with VT1350 trick?
and if 120hz with vt1350 is better than 144hz, now vt1350 is better or vt1502? ;p
And when i using 1502vt trick @ 1920x1080 and playing game with 800x600 its still working or i must create custom resolution 800x600 with 1502vt? Cause when i create 800x600 with 1502vt trick i've got full of artifacts :p
And when i use vt1502 trick at 1024x768 it works, i've got that what i need, full smooth nice quality etc. But i've got message "Incorrect cable, please use dvi dual link" but monitor still works (but i can't go to menu :p) i use dvi dual link ofc ;D
Waiting for response.
And when i opened service menu i've got this http://prntscr.com/44pa7e
but without a "Strobe duty", "Strobe phase" and "Single strobe" options.
Need help :p.
BenQ xl2411z questions :)
Re: BenQ xl2411z questions :)
144Hz + PWM-free or 120Hz + Benq Blur Reduction + vt trick. IMO 144Hz is the best, because my eyes feel better.
AMA High.
You can't use vt trick on 800x600, only 1920x1080.
AMA High.
You need to upgrade the monitor firmware to v2. You probably have v1, and you won't have those options in the v1 service menu.
About the incorrect cable:
If you used 1024x768 as a custom resolution in CRU.exe, its a known problem with lower 'detailed/standard resolutions', which cause the monitor to treat them like a 'preset' windows resolution. The VG248QE does the exact same thing and will have the same 'artifacts' appear; example, 1024x768@120hz as a preset will cause the incorrect cable error and I think 1024x768@100 hz will show a line artifact on the right edge. This happens on both the VG248QE and the benq so it MAY be a problem in CRU or with the panel circuitry itself (since they are both made by the same manufacturer).
1280x1024@100 does the same error msg.
What is that "PWM-free" ? Sry for posting so long but i read this thread once again now and i see this ;dkamill wrote:144Hz + PWM-free or 120Hz + Benq Blur Reduction + vt trick. IMO 144Hz is the best, because my eyes feel better.
AMA High.
Okay, now he said 144hz + pwm-free ye, can i on/off or change setting of PWM ?
kamill told me "144hz + pwm-free" how to set that pwm-free?
PWM-Free is automaticaly On, so You don't have to do anything, just turn off Blur Reduction
